Overdrive alternator pulley
Old Aug 8, 2006 | 10:35 AM
BottomFeeder's Avatar
BottomFeeder
I am taking my crazy project truck up to Burning Man in a few weeks. It will be enduring high heat, low constant idle, and a heavy load. You can think of the truck as having to endure a slow hot parade.
Some of the suggestions I heard were to put a smaller pulley on the alternator, so that it will produce enough current at idle speed. My questions are as follows: should I bother with a higher output (read expensive) alternator, or stick with mine as is? Can I drive with the smaller pulley on the interstate for 12 hours (how long it takes to get to Burning Man from my house)? Or will it blow up the alternator by spinning it too fast? It's possible, but a pain to change the pulley at Burning Man, but I really don't want to have to do car maintenance up there.
Any advice?
Old Aug 9, 2006 | 11:00 AM
BottomFeeder
Bump.
Does anyone know about alternators? Is it possible to spin one too fast? Thanks for any help.
Old Aug 9, 2006 | 11:05 AM
Mil1ion's Avatar
Mil1ion
Maybe ask franklin in the electrical forum ?
Personally ,I don't know of an alternator application that will fit this project.
What vehicles run tiny pulleys that would fit on a Ford engine bracket ?
Old Aug 9, 2006 | 02:15 PM
beartracks's Avatar
beartracks
Unless you have a hot rod engine that turns very high rpm turning the alt. and water pump faster wont hurt anything. Finding the pulleys is another matter. Power master offers an altenator pulley that is 2 1/4" in diamter I think. Another alternative might be a crank pulley with larger diameter pulleys on it.
iF you find any let us know. I would like to turn my water pump faster.
Old Aug 9, 2006 | 02:56 PM
BottomFeeder
I opted for a higher output alternator. It puts out more power at idle than the stock alternator could handle. This way I can run more stuff off of the DC.
Big Skier
31
Feb 27, 2019 07:21 AM
Dyllan78
Aug 11, 2012 08:50 PM
4WheelDriveVan
1997 - 2003 F150
Dec 10, 2010 07:30 AM
LCAM-01XA
Sep 16, 2010 11:52 PM
