Sponsored by: Real Truck
OASIS Report
Old Aug 8, 2006 | 08:21 AM
77f250sc's Avatar
77f250sc
OASIS Report
Can anyone run a complete report for me? Looking at purchasing this vehicle, would like to know if warrenty is intact, red flags, etc.
Thanks in adavance
VIN number
IFTWW33P34ED89163
Old Aug 8, 2006 | 08:40 AM
FortyFords's Avatar
FortyFords
go here flatratech.com ,join and follow their rules and they will help you.
only a dealer can do it for you.
Rich
Old Aug 8, 2006 | 08:55 AM
77f250sc's Avatar
77f250sc
Not finding it.
Can't seem to find anything with that address.
Old Aug 8, 2006 | 10:52 AM
FortyFords's Avatar
FortyFords
oops my bad flatratetech.com
Old Aug 8, 2006 | 11:51 AM
77f250sc's Avatar
77f250sc
No luck there
I need to try and get this fairly soon, not after 50 posts. (as one member just had to point out)
any other options?
Old Aug 8, 2006 | 12:39 PM
FortyFords's Avatar
FortyFords
find a dealer ,its there system!
or a tech thats willing to risk his job for you
carfax is your only other option
me if its a 6.0 stay away
Rich
Old Aug 8, 2006 | 12:44 PM
1ReDNeCK's Avatar
1ReDNeCK
Send me your fax # and I can send a report to you.
Old Aug 8, 2006 | 04:24 PM
SAYERS's Avatar
SAYERS
The guys at flatratetech.com are pretty fast in there replys
Old Aug 8, 2006 | 06:47 PM
99f350sd's Avatar
99f350sd
Is it true no Oasis or history if the vehicle is over 10 years old?
Dick
Old Aug 9, 2006 | 03:34 PM
77f250sc's Avatar
77f250sc
Still in need
Hoping someone can help me out.
Old Aug 9, 2006 | 05:30 PM
SAYERS's Avatar
SAYERS
I think all of the guys that answer the questions on flatratetech. com are ford master mech.
Old Aug 11, 2006 | 11:17 AM
77f250sc's Avatar
77f250sc
Need some feedback on report
Well recieved an Oasis report. Is this 6.0 good or bad? build date 7/02/04
1. engine died found had low ICP, replaced right oil rail and #4 injector.
2. found oil and vapor spraying, CAC pipe cracked, replaced (i dont see the oil fix on this line item
3. injector nozzel and egr sticking, replaced #2 injector and egr?
4. oil leaking out of bottom of turbo oil feed line, rplaced o-ring and gasket
5. new CAC, cracked.
There is a waring that states that this vehicle has a closed CUDL CONTACT,
the only thing I can find on this is related to the finacial aspect of the vehicle, is this in any way related to the warranty?
Old Aug 12, 2006 | 10:58 PM
walleyeman's Avatar
walleyeman
How did you get the report? I have been trying with no luck. I did not buy my truck from my local dealer so they are less than friendly.
Old Aug 13, 2006 | 07:46 AM
FortyFords's Avatar
FortyFords
sounds like a buy back vehicle or at least a vehicle with lots of trouble.
stay away
