clay bar question
Old Aug 8, 2006 | 04:19 AM
jasonschwenk's Avatar
jasonschwenk
clay bar question
sounds silly but after i clay bar my truck should i wash it again before i wax it?
Old Aug 9, 2006 | 08:25 AM
TruckDaddy's Avatar
TruckDaddy
Yes, wash it again with soap and water after you claybar it.
Old Aug 9, 2006 | 08:39 AM
jasonschwenk
thanks!It never said on the package
Old Aug 9, 2006 | 03:10 PM
HonorableKingCab's Avatar
HonorableKingCab
Washing post-clay is often a matter of opinion. Many don't. I'd suggest visiting Meguiars Online. They have numerous threads that answer questions about clay bars and more. It's a site that can be addictive. Good luck!
-Honorable
Old Aug 9, 2006 | 09:13 PM
jasonschwenk
thanks i never thought of the meguair's site. That's whose clay bar I bought
Old Sep 6, 2006 | 12:18 AM
LSUtigers's Avatar
LSUtigers
i'll whipe the car down again before i wax...but don' tusually wash it after clay
Old Sep 6, 2006 | 08:26 AM
TruckDaddy's Avatar
TruckDaddy
Check out Zaino: www.zainobros.com
Great products and lots of good tips.
Sounds like you've never used claybar. I'm telling you, you need to wash off the vehicle after claybaring.
Old Sep 9, 2006 | 06:23 PM
John311t's Avatar
John311t
After i clay bar i use the spray they give you for the clay bar on it to wash off the residue from the clay.
Old Sep 10, 2006 | 04:40 PM
lascrew's Avatar
lascrew
I've never washed my truck after claying.
..never had a problem with my results.
I use Adam's Polish and on their site their recommended process does not include washing after claying.
Results....
Old Sep 10, 2006 | 05:40 PM
TruckDaddy's Avatar
TruckDaddy
After you claybar, you will have some claybar residue on the vehicle, dirty claybar lubricant, and some of the impurities that you just cleaned off of the truck will be loose on the surface. It's like washing your truck with soap and water and not giving it a good rinse to get all the soap off. Makes no scense to me......
Old Sep 10, 2006 | 05:53 PM
lascrew's Avatar
lascrew
I'm not sure what other folk's processess are, but with me you only clay a small portion at a time. Obviously you use some type of detail spray (lubricant) for the application. With me, after I clay that particular area I re-apply detail spray and wipe that area clean.
After a I completely clay an area, like the hood for example, I entirely go over it again with detail spray. I then feel to make sure it is baby a@# smooth. If not, I re-clay the spots that require it. If it's cool then I proceed with polish and finish off with butter wax...
...with a mirror result that is rediculously smooth to the touch.
Old Nov 8, 2006 | 10:05 PM
TOL-Irene's Avatar
TOL-Irene
Jason, it depends on the clay, the lubricant, and the towel you use. Some clays leave residue and some do not. A microfiber towel will also remove virtually all residue if enough lubricant is used.
I prefer to 1) wash, 2) clay, 3) polish every 6 months, and wax as often as you wish. The polishing step will take care of the clay residue and bring the paint to perfection at the same time!
NMSU_RRAggie
Jun 24, 2015 10:21 PM
Tugly
Feb 16, 2015 05:36 PM
5.4L to Freedom
2009 - 2014 F150
15
May 29, 2014 11:40 AM
Jesser02EX
17
Oct 28, 2013 11:25 AM
brunnesa
Aug 24, 2013 10:53 PM
