Fuse panel layout
Old Aug 7, 2006 | 05:29 PM
gmerkman's Avatar
gmerkman
Fuse panel layout
I just bought a 1977 E-350, 460 CI, auto trans with a 14' box. I am using it to haul a large amount of equipment for my sound and recording business. It sat unstarted for two years, so I have done quite a bit of work to it. Just now I getting to the electrical.
The fuse panel is, well, gundecked, as we said in the USN. Someone wired in jumpers, there are broken clips, and worst of all, all the labeling is unreadable. For starters I need the fuse panel layout so I know what goes to what.
The local Ford dealer only has documentation back to 1980. They threw out everything older about five years ago. I have spent much time searching the Internet with no luck. I really don't want to spend the money to subscribe to one of the services for the little I would use it.
If anyone can help me I would really appreciate it. If so thanks in advance for your time and trouble.
Old Aug 7, 2006 | 06:36 PM
subford's Avatar
subford
This should be it:
http://i54.photobucket.com/albums/g9...al/76fuseE.gif
Old Aug 8, 2006 | 09:42 AM
rebocardo's Avatar
rebocardo
Now that is good help :-)
They are now very hard to find and special order at PepBoys, but, what you should consider is replacing the high load fuses with circuit breakers. When you get them from Pepboys you have to turn the "tube" part around so it fits in the fuse holder.
Being a 1976 and pretty simple, wiring harness wise, I would consider a fuse box replacement (Painless Wiring)so you can use the more modern fuses and circuit breakers.
axman
2004 - 2008 F150
Oct 30, 2016 07:31 AM
anttho
May 2, 2007 01:23 PM
Drevil
Sep 7, 2006 04:39 PM
SpykDaddie
2004 - 2008 F150
Feb 6, 2006 11:29 PM
sdsurf
Mar 19, 2002 03:46 PM
