295/75/16 pics???
Old Aug 7, 2006 | 04:52 PM
dsldandually's Avatar
dsldandually
295/75/16 pics???
does anyone thats running 295's have any pics???
thanks
Dan
Old Aug 7, 2006 | 05:30 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
On a dually? I have 305/70/16s on my dually. Check my gallery.
Old Aug 7, 2006 | 05:37 PM
dsldandually
no on a 350 SRW
Old Aug 7, 2006 | 06:39 PM
Uzumati's Avatar
Uzumati
Here's 305's
Old Aug 7, 2006 | 06:46 PM
BobbyDiesel71's Avatar
BobbyDiesel71
thanks
Dan
if you can go bigger, get some 305's
they will fill up the wheel well better
just make sure you get the tires in the correct load rating, E, right?
Nitto Terra Grapplers are E rated I had them and they were great!
Old Aug 7, 2006 | 06:50 PM
Fat Diesel's Avatar
Fat Diesel
Here's a pic of my truck.
Old Aug 7, 2006 | 08:53 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
i did the calculations, and a 295/75 is a 11.5W and 33.5" tall tire, while a 305/70 is a 12"W and 33" tall tire.
here is a pic of my truck before i lifted it with 305/70's.
and after the lift:
needs some 35's, eh?
Old Aug 8, 2006 | 06:59 AM
Robert6401's Avatar
Robert6401
I disagree with what everyone is saying about going with 305's, the 295's will be taller, and will fill the wheel wells better. Not to mention the fact that they are narrower, which is better for the stock wheels (assuming thats what you are running). Good luck.
Old Aug 8, 2006 | 11:55 AM
PowerstrokeJunkie
yes i believe most people do not take into consideration the actual sizes and width of the metric tire system. those who dont know think that a higher first number means it's a taller tire. in fact, it's a narrower tire. the second number determines the sidewall height in relation to the width of the tire.
305/25.4 = 12.0" wide. *.70= 8.4" of sidewall. two sidewalls= 16.8" +16" rim= 32.8".
295/25.4 = 11.6" wide. *.75= 8.71" of sidewall. two sidewalls= 17.42" +16" rim= 33.4".
Old Aug 8, 2006 | 10:39 PM
kbeefy's Avatar
kbeefy
Hmmm... maybe a bit confusing there, the first # is treadwidth in mm, the second # is aspect ratio (sidewall height expressed as a prrcentage of treadwidth) and the last is, of course the rim diameter.
A larger first # is always a wider tire (if mounted on identicle rims) the hieght varries depending upon all the numbers.
Old Aug 9, 2006 | 12:16 PM
DirtyDieselPhil's Avatar
DirtyDieselPhil
I just installed 295/75's on my 2002 (had 285's before) - I think they look great! (I can't post photos, though) I had to remove the mud flaps, however - too much rub. Also had to trim the front air dam slightly (maybe 1" at the bottom, tapers to 1/2" at the top). My rig has been levelled and has 10" rims.
try this link to compare tire sizes:
http://www.1010tires.com/tiresizecalculator.asp
Phil
SneakyF350
6.7L Power Stroke Diesel
62
Jul 3, 2014 12:58 PM
CBBeaty
Oct 25, 2013 12:18 PM
peckerwood
Feb 14, 2012 12:36 PM
NASSTY
EcoBoost (all engine sizes)
May 2, 2011 04:22 PM
