weak spark
Old Aug 7, 2006 | 04:20 PM
GOTH_TRUCKER's Avatar
GOTH_TRUCKER
Smile weak spark
ok my 84 150 with ds2 set up and everything is new i have a very very weak spark wut would cause this thanks ya'll
Old Aug 7, 2006 | 09:17 PM
havi's Avatar
havi
I'll have the Roast Duck
My first suggestion is to clean the ground on the coil or replace the coil if you haven't already. I guess you could use an ohmmeter and measure the resistance in the ds2 wiring and match it up with the factory specs. And do the same with voltage. IMO, weak spark is better than no spark when it comes to diagnosing. Good luck.
Old Aug 7, 2006 | 10:10 PM
GOTH_TRUCKER
wut are the factory specs?
Old Aug 8, 2006 | 04:17 PM
stractor's Avatar
stractor
You could have misatched or noncompatable components due to the parts swaping. They should all be from the same year and model.
stractor
Old Aug 9, 2006 | 02:38 PM
GOTH_TRUCKER
ya they are all from the same year
