power windows
Old Aug 7, 2006 | 02:10 PM
threedeekid's Avatar
threedeekid
power windows
How to remove the power window motor, both sides on a 89 Ford F250
Last edited by threedeekid; Aug 7, 2006 at 02:11 PM. Reason: need to indicate year and model of truck
Old Aug 7, 2006 | 02:18 PM
Josh88Ford's Avatar
Josh88Ford
After you take off the interior panel, you will have to drill a hole. I can't remember if its one or two holes that need to be drilled to get to the screws, but if you look, you'll see them. slider is seperate from the motor, prop the window up with something
Old Aug 8, 2006 | 09:55 AM
GWall's Avatar
GWall
You'll have to drill two holes. There are some dimples that look as though they were made with a punch that indicate where to drill. Drill a 1/2 inch hole and remove the screws with a 5/16 inch socket.
