Inner fenders
Old Aug 6, 2006 | 10:58 PM
lilpro's Avatar
lilpro
Inner fenders
SO i have been looking at a lot of different web sites but no carry it or there out of stock. So i was wondering since i have a 72 f100 if i was to buy 73 f100 inner fenders if they would work?
Thanks
Michael
Old Aug 6, 2006 | 11:55 PM
Fomoko1's Avatar
Fomoko1
Yes and no. They will fit but there will be a problem with installing the hood hinges. I believe this has been discussed here a while back so if you do a search you should be able to find some info. Other wise someone that has done this might jump in and save you the trouble of the search.
Old Aug 7, 2006 | 07:53 AM
4Cammer72's Avatar
4Cammer72
if you go 73 and later you need the later hinges also. some have had to shim the hinges to fit the hood properly and some dont. my guess is improper alignment of the fenders when they were installed. but the good thing is the later 73 and up inners are galvanized and are much more resistant to rust.
Old Aug 7, 2006 | 10:13 AM
lilpro's Avatar
lilpro
Thumbs down
Would i be able to just shim the 72 hinges? Becuase im looking at NPD and they want $612 for one hinge!
Old Aug 14, 2006 | 11:20 PM
beedevil1973's Avatar
beedevil1973
have you checked dennis carpenter or lmc truck for the inner fenders. i bought mine from dennis carpenter and they bolted up perfectly.
Old Aug 14, 2006 | 11:51 PM
lilpro's Avatar
lilpro
Did you buy the 72 or 73? Becuase i remeber calling them and i cant remeber if they said they didny have them in stock or if they only has one side.
Old Aug 15, 2006 | 12:27 AM
Mil1ion's Avatar
Mil1ion
Macs should have them.
http://www.parts123.com/parts123/yb....ta~partsort~A2
Old Aug 15, 2006 | 11:16 PM
beedevil1973
when i called a couple of motnhs ago and ordered them they had both. carpenter that is. if they don't lmc or macs should. you really don't want to put the 73 or newer ones in because there is way to much fabricating you have to do to make it work and it's just a big pain in the butt.
Old Aug 16, 2006 | 12:08 PM
4Cammer72's Avatar
4Cammer72
NO the hinge sits on the opposite side of the top flat on the inner fender 73 and on.
