Head Replacement
Old Aug 6, 2006 | 08:19 PM
bazlow's Avatar
bazlow
Head Replacement
I finally broke down and got a set of rebuild heads for my 1990 F-150 and started working on the replacement this weekend. I have one question about the whole affair. That is, the components from the old heads, rods and rockers are highly carbonized. Probably 1/32" of hard black coating on everything. I got a can of Gunk cleaner and spend all day trading out parts from the driver side head to get it off. It takes 3-4 30 minutes soaks to get the parts clean. Granted it's an old engine with 160000 miles on it but is this normal?
I was blowing a lot of smoke out of the valve covers which I attributed to shot valves. Compression on all cylinders is still in the 140-160 range. And, I'm pretty religious about changing the oil out at regular intervals since I bought the truck. Was it the hot gasses blowing out of the valves that caused the heavy carbonization or is this normal for an engine this old?
A
Old Aug 6, 2006 | 09:04 PM
Conanski's Avatar
Conanski
Probably excessively worn valve guides, and worn out or missing stem seals. You can check this once you get the head off. Remove a valve spring with a spring compressor, and try to wiggle the valve with the head just above the seat. It should not move at all on a new head. My guess you have tons of play on your valves.
Old Aug 6, 2006 | 10:39 PM
biggreentank's Avatar
biggreentank
I've seen high carbon buildup on the neck of valves but never on the actual rockers. Was it ever run hot or anything? 160000 is not a ridiculous amount of miles and the rockers shouldn't have looked very bad.
Old Aug 7, 2006 | 07:50 AM
MustangGT221's Avatar
MustangGT221
Moved to appropriate forum per our "Read First!" annoucement at the top of the 87-96 forum...
https://www.ford-trucks.com/forums/1...all-users.html
wahlturfcare
Nov 7, 2013 02:13 PM
cdawley4
Feb 15, 2011 08:47 AM
gearloose1
Jun 11, 2010 08:15 PM
Bronc1
1997 - 2003 F150
Nov 16, 2009 09:11 PM
AeroRob
Aerostar
15
Sep 23, 2004 04:27 PM
