Sponsored by: Kumho
4X4 Front axle alignment??
Old Aug 6, 2006 | 06:12 PM
Eric1966's Avatar
Eric1966
I just R&R the front differential in my 66 F-100 4X4 and have the coil springs, radius arms, and track bar hooked up, but it looks a little off, so i measured the distance from the frame rail to the center of the steering knuckle and the drivers side is 1 inch farther to the outside than the right side. Is the correct? Any ideas? I thought the track arm would automaticly line it up lateraily when I got it hooked up, but the different measurements have me stumped. Any help would be great.
Thanks...Eric
Old Aug 14, 2006 | 05:47 PM
1975Ford's Avatar
1975Ford
Maybe the track arm was installed backwards???
Does the truck have a lift kit?
Was track bar bracket replaced?
buck
