Vibration/humming
Old Aug 6, 2006 | 05:36 PM
IowaTower's Avatar
IowaTower
Vibration/humming
'79 150 4x4, C6, 351M. I took my truck out on the interstate this afternoon, first time in quite a while, and I noticed an all-over vibration and humming starting at 65mph, getting worse with speed. It doesn't exist, that I can tell, below 65.
What could be causing this?
Old Aug 7, 2006 | 10:14 AM
DustinDLamb's Avatar
DustinDLamb
Have you checked your U-Joints yet. Or it could be a rear end. I would start by doing just a good all around inspection.
Old Aug 7, 2006 | 10:45 AM
Purely Ford's Avatar
Purely Ford
You might have an axle or wheel bearing problem. I would raise each wheel and check them carefully. A carrier bearing might also be the culprit, so look there too.
