Sponsored by: Real Truck
Need Quick Answer
Old Aug 5, 2006 | 04:10 PM
whododat's Avatar
whododat
Need Quick Answer
Can I fit 17" rims on my 05 350 sd 4X4, fx4. It currently has 18 inch rims.
Old Aug 5, 2006 | 04:16 PM
Lance_I's Avatar
Lance_I
Yes but you'll have to have different tires too.
Old Aug 5, 2006 | 04:17 PM
whododat's Avatar
whododat
No problem with that, I have a guy that took his 17"' bf goodrich's off of his hummer brand new.
Old Aug 5, 2006 | 04:18 PM
CounterMaker's Avatar
CounterMaker
i looked on the ford website and it shows that if its a dually the standard wheels are 17" and the standard for the single rear wheel are 18"...but i dont see why you couldnt be 17" rims on a single rear wheel...i have a 2006 f250 and the wheels are 17"
Old Aug 5, 2006 | 04:44 PM
Bear Hunter's Avatar
Bear Hunter
...again, it depends on the size of the tire. 17" is the size of the rim... There are many sized tires that could fit on there. I am not familiar with Hummer...so I don't know what size their stock tire is.
You could run any sized rim you wanted as long as the bolt/lug pattern and backspacing was correct. For example, Ford offers 20" rims as an option on some Superduties...but you won't fit a 40" tire on those 20" rims under a stock truck.
Old Aug 5, 2006 | 04:52 PM
whododat's Avatar
whododat
what is the bolt pattern I am looking for on a 17 inch rim?
Old Aug 5, 2006 | 05:06 PM
Bear Hunter
You are looking for 8x170mm pattern...its the same as your 18" rims...rim size has nothing to do with it.
Edit: I see you have an 05...they have larger brakes.. So you would be limited as to how small you can go with the rim. I'm pretty sure a 17" would fit, but don't hold me to it.
Old Aug 5, 2006 | 05:19 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I've heard that the Hummer stock tires work great with the 250/350.
Old Aug 5, 2006 | 05:24 PM
whododat's Avatar
whododat
what about the offset and whatever else
Old Aug 5, 2006 | 05:26 PM
Autobahn F-250 Lariat's Avatar
what size are the bfg's off the h2
Old Aug 5, 2006 | 05:28 PM
Bear Hunter
Well there are plenty of 05's and above running around with 4.5" of backspacing...heck, I'm going to be doing it myself.....but I think the backspacing on 05's and above are 5.25 or something like that.
Why don't you just tell us what kind of rim you are looking at?
Old Aug 5, 2006 | 05:30 PM
whododat's Avatar
whododat
315/70/17 is the size of the bfg's
Old Aug 5, 2006 | 05:31 PM
i see -6 offset, 0 and 25
http://www.discounttire.com/dtcs/sea...vid=009019&bp=
http://www.discounttire.com/dtcs/infoWheelOffsets.dos
Old Aug 5, 2006 | 05:32 PM
Bear Hunter
Well.. They would be stuffed in a 99-04. I have heard that you can run a bit larger on 05's and above with stock suspension.
Maybe someone who has an 05 and above will chime in if they have any rubbing issues with 315's and stock suspension
Old Aug 5, 2006 | 05:37 PM
Bear Hunter
Originally Posted by Autobahn F-250 Lariat
I'm not for sure what it is exactly on 05's and above...I seem to recall seeing 5.25 to 5.5 being posted
