96 A/C Leak
During these high temperatures it seems that the Aeros A/C just died I can't say for sure how many days it took from good cool a/c to nothing but definately less then a week. The clutch cycles too fast which tells me low refrigerant charge.
I'm going to pick up some UV dye to find the leak once I do however and have the system discharged I will most likely need to replace a hose (hoping the leak isn't in the evaporator or condenser).
According to the Ford service manual whenever a major part of the A/C system is replaced including hoses the accumulator should be replaced I will replace that however are there any other parts I should replace while I'm in there besides the accumulator and the hose?
Also since Ford refers to the hoses by what state the R-134a is in as it flows through them I want to make sure I have them straight in my head so I don't order the wrong one by mistake.
Suction Line - from the accumulator to the compressor inlet
Discharge Line - from the compressor outlet to the condensor
Liquid Line - from the condensor to the evaporator (I assume this line is also where the orifice tube is located).
Also are there any special tools I'll need to disconnect the fittings on the hoses similiar to the annoying quick disconnects on the heater core hoses.
Since you are going to open the system, disconnect the liquid line that enters at the bottom of the evaporator. Remove the old orifice tube and replace. I don't know what the difference is, but Ford has two different O tubes for the front and back unit. The one for the front is orange in color and there is an arrow on the Orifice indicating which end is inserted into the evaporator first. The old O tube can be removed with a pair of needle nose pliers.
