Rocker Arm Assembly
Old Aug 5, 2006 | 02:17 PM
richlars's Avatar
richlars
Rocker Arm Assembly
Putting my 93 460 back together and got to the rocker arms. On the inside of the rocker arm and the bottom of the fulcrum on the mating surfaces are tapering grooves. When I reassemble do I match these grooves or cross them?
Thanks for any help,
Rich
Old Aug 9, 2006 | 08:00 AM
William's Avatar
William
I match mine, but I doubt that it matters. Then again if your wrong you will at least be 100% wrong. I just make sure to check for abnormal wear and any rough areas. I also use a magnet to be sure all are made of steel. I have found a mix and match with aluminium and steel. I prefer steel!
