Sponsored by: Auxito
4.2 gone bad
Old Aug 5, 2006 | 01:41 PM
93RangerXL4x2's Avatar
93RangerXL4x2
4.2 gone bad
My 98 4.2 well its not running to good today this morning it would just want to almsot stall I put the truck in Reverse to back up and it was very rough back to Drive it took a minite for the engine to rev out with the accelerator to the floorwhen i get to a stop sign of stop light its gotta be put into Neutral to prevent a stall on a busy road now ok im at a stop light put the truck back into drive and theres a loud rattle almost sounds like a Knock but i must be something losse cant put my finger on it this problem has been getting worse over the last 3 weeks
Old Aug 5, 2006 | 10:45 PM
70f100longbed's Avatar
70f100longbed
HOLY RUN-ON SENTENCE BATMAN!!!! Slow down a little and put some punctuation in there. I had to read that 3 times to understand it. Sounds like a large vaccum leak to me. Make sure the PCV hose elbow doesn't have a hole in it. Look under the intake right behind the throttle body. Make sure all other vacuum hoses are connected. Is the check engine light on? Does it use coolant? How does the oil look? These engines are also bad for intake gaskets leaking.
Old Aug 7, 2006 | 03:19 PM
fplorer's Avatar
fplorer
You might check the valve springs. Is there a check engine light?
Old Aug 7, 2006 | 07:39 PM
93RangerXL4x2
yes there is a check engine light
Old Aug 8, 2006 | 07:55 PM
70f100longbed
Check the codes and post them here. Autozone might still do it for free.
Old Aug 8, 2006 | 08:51 PM
93RangerXL4x2
I Will post post them when I get the truck checked out, Should be within the next few days.
