Sponsored by: Kumho
front springs
Old Aug 5, 2006 | 08:57 AM
f350custom's Avatar
f350custom
front springs
anyone know how wide the front leaf springs are on a 91 f350? what i am doing is converting a 91 f350 dually 2wd to 4x4. used f250 spring hangers . trying to add a 6 inch lift so i am looking to see if there is a difference in spring lenght an with on a 250 verc a 350. thanks bigjoe
Old Aug 5, 2006 | 12:56 PM
mxzx's Avatar
mxzx
both are 3 inches
Old Aug 6, 2006 | 08:38 AM
f350custom's Avatar
f350custom
so the you think the only difference is the f350 springs are just stronger than
the f250 springs. im thinking i might us f250 springs on the front and just add a leaf
and blocks in the back with ladder bars.
Old Aug 6, 2006 | 03:52 PM
mxzx's Avatar
mxzx
I'm sure the 2 springs are identical dimesion wise. I think the difference is weight carrying capacity and ride height. With vehicle weight on them the f250 has a negative arch while the f350 springs are pretty much flat. A stock 350 sits a little higher than a stock 250.
hope this helps
Old Aug 6, 2006 | 05:57 PM
f350custom's Avatar
f350custom
thanks for the info. that what i was thinking.
