Truck Died!
Old Aug 4, 2006 | 12:02 PM
deetown's Avatar
deetown
Truck Died!
I have a 2000 powerstroke all stock that started to run rough and now won't run. It was getting low on fuel but not i don't think it was empty. Please help! It will start but won't idle.
Old Aug 4, 2006 | 12:32 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Can you get a few more gallons of fuel in it? If the problems clears up when above 1/4 tank then it is a problem with an inlet valve down in the tank. If that does not help it could be a plugged fuel filter, bad fuel pump, cam sensor, or any of several other things. Did the service engine soon light illuminate before it died?
Old Aug 4, 2006 | 03:44 PM
deetown's Avatar
deetown
Thanks for the reply. It must have been air in the lines, cause when I added more diesel and opened the fuel/water valve, air popped out. After that it would idle and now it seems to have fixed the problem. I'm on a tight schedule so is there anything I should do now before I hit the road again?
Old Aug 4, 2006 | 07:14 PM
Kwikkordead's Avatar
Kwikkordead
Fill it all the way up and keep it above 1/4 tank.
