Installing gauges
Old Aug 4, 2006 | 09:12 AM
brian worthan's Avatar
brian worthan
Installing gauges
I am wanting to install working gauges on a quad "A" pillar and am wondering where you hook up the sending units for oil pressure and oil temp gauges on the 6.0. motor.
Old Aug 4, 2006 | 04:52 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Not sure on the oil pressure, but I installed my oil temp by tapping into the top of the oil filter cap. I added a short piece of pipe into the top of the cap using pipe dope (on both ends) then the temp bulb. The short piece of pipe is so the bulb doesn't contact the spring inside the filter and also makes a nice reservoir for the temp bulb to sit into. Make sure you can close the hood without it contacting the probe BEFORE you add all the pipe dope.
Old Aug 4, 2006 | 08:24 PM
LAWNMOWER MAN's Avatar
LAWNMOWER MAN
For Oil Press. You Can Order A New Oil Filter Cap That Is Metal From Oilgurrd Bipass Filters It Already Is Threaded Call Autometer And Get Their Extension Kit It Has Braded Line That You Can Attach To The Cap With The Fitting And Mount The Sender Whereever You Want To, The Tech Guys At Autometer Are Really Helpful, The Water Temp -there Is A Removable Plug With An Allen Screw At The Rear Of The Block On The Drivers Side Just Above The Exaust Manifold You Can Put Your Sending Init There, Auto Meter Has The Right Adaptor That You Need , Have You Thought About An Egt Gauge?
Old Aug 4, 2006 | 11:06 PM
raptor131's Avatar
raptor131
yeah but he wants oil temp not the water. heheheehhee
Old Aug 4, 2006 | 11:26 PM
LAWNMOWER MAN
Oops Sorry Thought I Read Water Temp My Bad But I Got The Water Temp Right Lol
