High altitude IP
Old Aug 3, 2006 | 09:41 PM
Bigredcrew's Avatar
Bigredcrew
High altitude IP
I was talking to a parts guy at a local Ford dealership trying to get the part number for my IP (I thought the data plate was gone, turned out it was totally disguised with dust and grime); he asked if I knew if I had a high altitude IP. I didn't know there was such a thing. Apparently some trucks came equipped with them. Anyone heard of this before? Can I install one in place of what's there? Or should I just be happy...
Old Aug 3, 2006 | 10:25 PM
Guatman's Avatar
Guatman
I might be wrong but I think the only difference is the pressure setting. It is reduced a little to compensate for altitude.
Old Aug 4, 2006 | 05:50 AM
pnose's Avatar
pnose
Guatman is correct,the fuel is turned down to reduce smoke at high alt,if you live at a high alt you may want the same pump installed,if not a reg pump will cause no ill effect.
GT4point6
Modular V10 (6.8l)
Sep 27, 2007 02:54 PM
mtgrzlyman
Sep 18, 2005 05:30 PM
rsheltro
Dec 25, 2002 02:14 AM
Monsta
Modular V10 (6.8l)
Apr 1, 2002 01:10 AM
toadmaster
1978 - 1996 Big Bronco
Sep 6, 2000 02:33 PM
