Sponsored by: Auxito
losing power not alt. ???
Old Aug 3, 2006 | 08:04 PM
9-onefifty-7's Avatar
9-onefifty-7
i have a 97 f150 4.6 150000mi recently changed alt. and battery new sparkplugs and wires. i replaced the alternator when it died the first time, then it died again so figured it was a bad battery. ive had autozone check it and it read good out put from the alternator and i put a new battery in. now it died again when i was driving, the battery slowly drains.....??????
Old Aug 4, 2006 | 12:48 AM
Racerguy's Avatar
Racerguy
Hi and welcome to the forum
Does the battery light on the dash come on when you turn the key on and then go off when the engine starts?
Old Aug 4, 2006 | 01:39 AM
fbodyfan's Avatar
fbodyfan
The truck died when you were driving? That puts it on the alternator right there. You can remove the battery from a car when the engine is running, and it will continue to run. If it died, you aren't getting spark because the alternator isn't providing enough power.
