Sponsored by: Auxito
power door locks
Old Aug 3, 2006 | 07:40 PM
tdark's Avatar
tdark
power door locks
I have a 2003 f150 super cab that the power door locks all of a sudden quit working. I can only lock manually one door at a time. Is this a problem that other ford truck owners have had? It worked this morning but when I got in the truck after work it would not lock from the door panel switch. I have check the fuses but all are good.Thanks for any tips before I take this thing to the dealer.Tom
Old Aug 4, 2006 | 12:54 AM
Racerguy's Avatar
Racerguy
Did you check the fuses under the hood as well as under the dash?
The fuse for the door locks is #8 under the hood.
Old Aug 4, 2006 | 05:58 AM
tdark's Avatar
tdark
I will check that one and post back. Thanks
Old Aug 4, 2006 | 08:49 AM
ClydeDriver's Avatar
ClydeDriver
I have a problem with my door locks as well. 98 F150 5.4l one day the remote would not open the drivers side door. 2 clicks would open the passenger’s side though. I reset the system as per the owner’s manual but it didn’t work. The problem stayed for about 3 weeks and I opened the door manually. I decided to bring it to the dealer and have the cruise control recall taken care of and asked them to look at the un-locking issue. 2 days before it went in, it started working again. What should I check if this happens again?
Old Aug 4, 2006 | 08:30 PM
tdark's Avatar
tdark
The fuses were ok. I found out that I still have a warranty on this and I will let the dealer fix it. I will let everyone know the fix if they tell me. Thanks, tom
