Is it worth it?
Old Aug 3, 2006 | 03:06 PM
hcashooter's Avatar
hcashooter
Is it worth it?
I am looking at a 1996 F250 Extended cab LWB 4X4 with 196000 miles. A new motor was installed at 32000. The truck has new tires 5th wheel hitch, brake regulator, tool box, and over all is in good condition.
The guy is asking 9,000 for the truck because he now has a desk job for the company and does not need it. He was an inspector and pulled a camper to the job sites for housing. I have had 150's but never a 250 and I was wondering about the engine. I always hear about 300,000 as it is some magic number for miles on a diesel.
Any help or suggestions would be great!
Old Aug 3, 2006 | 03:52 PM
Phydeaux88's Avatar
Phydeaux88
I don't know where the 300,000 figure comes from.
Mostly what you hear around here is 400 to 500,000 miles are very possible from the 7.3L PSD, with good care.
The core engine for the 7.3L is Internationals T444E. It is commonly found in delivery vans and tow trucks, high milage vehicles.
Old Aug 3, 2006 | 09:39 PM
1997F-350's Avatar
1997F-350
i wouldnt be scared of 190. shoot i know some guys that just starting to mod there trucks at 300 with injectors and chips etc. if its nice go for it.
Old Aug 5, 2006 | 11:57 AM
Leader's Avatar
Leader
I bought mine with 165,000 miles on it..... Got 369,000 on it now. Still same injecters & glow plugs. Did do water pump and air pump. Mostly just what I consider to be normal maint.
Old Aug 7, 2006 | 01:03 AM
Dustin1690's Avatar
Dustin1690
Basically depends on you since your looking at the truck so do you think it is worth it for $9000 if its in good shape and what your looking for go for it..
Old Aug 8, 2006 | 01:08 PM
strokin7.3's Avatar
strokin7.3
don't be scared
high miles is nothing on the powerstroke if it's been maintianed well. Check the rest of the truck for wear like the front and rear end also the brakes and tranny. That year of truck only came with a dana 50 up front so check the joints if its 4x4. changing the oil every 3 thousand miles, keeping the correct coolant and coolant additive levals, change the fuel filter, and keep the glow plug system working properly will let the powerstroke give you many more years of service.
Old Aug 8, 2006 | 01:18 PM
Leader's Avatar
Leader
Ahhhhhh ... I sure never changed the 14 Qts of perfictally good oil in my truck every 3000 miles. The book calls for 5000 miles & I have always gone 10,000 between oil & filter changes. Rotella 15-40 dino oil for the last 200,000+ miles.
Old Aug 8, 2006 | 02:23 PM
strokin7.3's Avatar
strokin7.3
It's not the oil that break's down it's the anti-foaming agents in the additive pack in the oil for the high pressure injection system running at several thousand psi. I spend 300 a month on fuel so i don't really notice the 35 every 3000 for rottela and motorcraft filter from wally world. The same oil can stay in a cummins for 15000 miles but i'm a ford man. I drain my oil out and give it to my cheap friend with the cummins. I wish the additive pack was as good as the oil it came in. Well it's good but not quite good enough. You can buy the anti-foam additive and just dump it in. Semi trucks use it and they keep there oil in for 40-50 thousand miles. That oil has a good base stock that will protect your moving part's far past 3000 miles, but it's not about that it's the high pressure injection system and the hydraulicly accuated injectors.
Old Aug 8, 2006 | 02:48 PM
Leader's Avatar
Leader
Well with over 369,000 miles on the origanal injectors (and everything else inside) I don't see that as a problem . I sometimes spend more then $300 a week on fuel and the cost of 3 to 1 oil changes sure makes a differance to me.
Lets see 120 oil changes at $35 = $4200 compaired to my 36 oil changes at $35 = $1260... $3000 in my pocket...
Old Aug 8, 2006 | 03:33 PM
strokin7.3's Avatar
strokin7.3
congratulations on all those miles. These are just great truck's. I hope mine last's that long. Maybe i'm a sucker to the oil companies. I'm strict when it comes to my truck i even add bio deisel to it for lubricity and change fuel filter every 10000. Also I wax that baby every month.
Old Aug 8, 2006 | 03:37 PM
Leader's Avatar
Leader
It should last a lifetime...
Old Aug 11, 2006 | 12:30 PM
Cuda_jim's Avatar
Cuda_jim
Last post date 10-22-2023. Bumping to fix date.
Rum-N-Gun
17
Jun 7, 2014 06:35 AM
Pheadrus
Dec 24, 2013 03:38 PM
Bdox
20
Nov 9, 2011 05:52 AM
cwc
2004 - 2008 F150
Apr 26, 2007 03:09 PM
WillowBrooke
Car/truck Buying Advice
Nov 21, 2002 11:34 AM
