rear main seal
Crankshaft Rear Oil Seal
<TABLE cellSpacing=0 cellPadding=3 border=1><CAPTION>SPECIAL SERVICE TOOL(S) REQUIRED</CAPTION><TBODY><TR><TH vAlign=bottom align=middle>Description</TH><TH vAlign=bottom align=middle>Tool Number</TH></TR><TR><TD style="BORDER-BOTTOM: medium none" vAlign=top align=left>Rear Crank Service Set</TD><TD style="BORDER-BOTTOM: medium none" vAlign=top align=left>T94T-6701-AH</TD></TR><TR><TD style="BORDER-BOTTOM: medium none" vAlign=top align=left>Rear Wear Ring Remover</TD><TD style="BORDER-BOTTOM: medium none" vAlign=top align=left>T94T-6701-AH1</TD></TR><TR><TD style="BORDER-BOTTOM: medium none" vAlign=top align=left>Crankshaft Rear Wear Ring Remover Sleeve</TD><TD style="BORDER-BOTTOM: medium none" vAlign=top align=left>T94T-6701-AH2</TD></TR><TR><TD style="BORDER-BOTTOM: medium none" vAlign=top align=left>Crankshaft Seal Replacer</TD><TD style="BORDER-BOTTOM: medium none" vAlign=top align=left>T94T-6701-AH3</TD></TR><TR><TD style="BORDER-TOP: medium none" vAlign=top align=left>Crankshaft Seal Replacer</TD><TD style="BORDER-TOP: medium none" vAlign=top align=left>T94T-6701-AH4</TD></TR><TR><TD vAlign=top align=left>Forcing Screw</TD><TD vAlign=top align=left>T84T-7025-B</TD></TR><TR><TD vAlign=top align=left>Remover Tube</TD><TD vAlign=top align=left>T77J-7025-B</TD></TR><TR><TD vAlign=top align=left>Driver Sleeve</TD><TD vAlign=top align=left>T79T-6316-A4</TD></TR></TBODY></TABLE>
Removal
- Remove the flywheel (6375).
- Remove the five crankshaft rear oil seal retaining bolts and the crankshaft rear oil seal (6701).
- Clean the crankshaft rear oil seal sealing surfaces.
- Inspect the crankshaft rear oil seal for damage. Replace as necessary.
- If equipped with a crankshaft wear sleeve, use Crankshaft Rear Wear Ring Remover T94T-6701-AH1, Forcing Screw T84T-7025-B, Remover Tube T77J-7025-B and Crankshaft Rear Wear Ring Remover Sleeve T94T-6701-AH2 to remove the crankshaft rear wear sleeve.
<TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1</TD><TD>—</TD><TD>Crankshaft Wear Ring (Part of 6701)</TD></TR><TR vAlign=top><TD>2</TD><TD>T94T-6701-AH1</TD><TD>Crankshaft Rear Wear Ring Remover </TD></TR><TR vAlign=top><TD>3</TD><TD>T84T-7025-B</TD><TD>Forcing Screw </TD></TR><TR vAlign=top><TD>4</TD><TD>T77J-7025-B</TD><TD>Remover Tube </TD></TR><TR vAlign=top><TD>5</TD><TD>T94T-6701-AH2</TD><TD>Crankshaft Rear Wear Ring Remover Sleeve (if Installed)</TD></TR></TBODY></TABLE>
Installation
- Apply Silicone Rubber F5TZ-19G204-AB or equivalent meeting Navistar specification D15-5012 Type 2 to the rear oil seal retaining ring and five crankshaft rear oil seal retaining bolts.
- Using Crankshaft Seal Replacer T94T-6701-AH3, Crankshaft Seal Replacer T94T-AH4 and if wear sleeve is to be replaced, Driver Sleeve T79T-6316-A4 and guide pins (part of T79T-6316-A), install crankshaft wear ring and crankshaft rear oil seal.
<TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1</TD><TD>—</TD><TD>Guide Pins (Part of T79T-6316-A)</TD></TR><TR vAlign=top><TD>2</TD><TD>T94T-6701-AH4</TD><TD>Crankshaft Seal Replacer</TD></TR><TR vAlign=top><TD>3</TD><TD>T94T-6701-AH3</TD><TD>Crankshaft Seal Replacer</TD></TR><TR vAlign=top><TD>4</TD><TD>T79T-6316-A4</TD><TD>Driver Sleeve</TD></TR><TR vAlign=top><TD>5</TD><TD>6701</TD><TD>Crankshaft Rear Oil Seal</TD></TR></TBODY></TABLE>
- Install the five crankshaft rear oil seal retaining bolts.
- Remove installation tools.
- Install the flywheel.
