My '65 VIN # etc.
Old Aug 7, 2002 | 08:19 PM
dgpruitt's Avatar
dgpruitt
Post My '65 VIN # etc.
Hi,
Here's my vin info. Would someone decode this for me?
F10JD637070
115 0 F10 381 F 09
5000 129 4000 75
Thanks,
Daniel
Old Aug 7, 2002 | 08:43 PM
banjopicker66's Avatar
banjopicker66
My '65 VIN # etc.
F10 = F100
J = 6 Cyl 240 CID
D = Dallas Assembly Plant
637xxx = January, 1965
115 = 115" wheelbase
0 = Color Code =
F10 = F100 Series
3 = Paint/Color Code = Light Blue
81 = Standard enclosed cab
F = Transmission = Synchronized 4 speed Warner T-98
09 = Rear End = Ford 9" rear, 3.70 ratio, 3,300 lb cap (this doesn't agree with the 5000 Max GVW. Not sure why.)
5000 = Max GVW
129 4000 = 129 HP @ 4000 RPM
75 = District Service Office = Phoenix
Old Aug 22, 2002 | 04:44 AM
Papas Ford Girl's Avatar
Papas Ford Girl
My '65 VIN # etc.
[updated:LAST EDITED ON 22-Aug-02 AT 05:50 AM (EST)]John, I noticed you decoded the VIN# for someone with a '65 a few weeks back...
I've decoded my VIN, with the exception of the DSO code - i.e., what resource do you use to look that up?
my DSO code is 72
***NEVERMIND THAT Q - JUST FOUND A MESSAGE YOU SENT BACK IN MAY REGARDING A "72" DSO - SAN JOSE DISTRICT, RIGHT??
This may sound stupid, but... I'm learning - & I see a lot of questions answered by you!
My rear axle is Dana 60 -full floating(I looked)- but the code on the VIN plate for the rear axle RATIO says "B4" (which Chiltons doesn't have anything listed before 1973)- Do you know what that means?
Thanks!
'66 F250 Custom Cab Camper Special -352 v-8 "Ol Betsy"
Old Aug 22, 2002 | 06:43 AM
banjopicker66
My '65 VIN # etc.
>a few weeks back...
Elizabeth:
1. I have a set of dealer parts volumes from 1967. It has a wealth of information in it. I also have the shop manuals for repairs, but they aren't as valuable for information. Amnd yes, DSO 72 is San Jose.
2. B4 for 65 is a Spicer (= Dana?) locking rear, 4.10 ratio, 5,200 lbs capacity. (B4 for earlier is the same axle and cap, but higher ratio.)
Hope this helps!
Old Aug 24, 2002 | 01:47 AM
Papas Ford Girl
My '65 VIN # etc.
Thanks for all your help!! I appreciate the info. It DOES help. I'm working on building my handbook/manual library.
I'm sure I'll be back w/more Q's soon!
Old Aug 31, 2002 | 08:44 PM
oldroady's Avatar
oldroady
My '65 VIN # etc.
checked my books as well, yep a b4 is a 4.10, same as mine. sounds pretty wound up about 75, doesn't it?
Old Sep 1, 2002 | 11:26 AM
bmoran's Avatar
bmoran
My '65 VIN # etc.
