will hubs fit?
Old Aug 2, 2006 | 07:32 PM
76F250Gal's Avatar
76F250Gal
will hubs fit?
will 3/4 ton hubs and roters fit on a 1/2 ton axle? Can the caliper be reused or do i need a new one? Can the caliper bracket be reused or will i need a new one? Will this setup fit in 15" rims?
Old Aug 2, 2006 | 08:51 PM
RCrawler's Avatar
RCrawler
The F250 uses dual piston calipers and larger rotors so the 1/2 ton calipers or brackets will not work. I think that the knuckles would need to be changed as the caliper mounting is part of the knuckle.
I don't think that you will be able to clear the dual piston calipers with 15" wheels.
Jason
