Antifreeze?
Old Aug 2, 2006 | 07:31 PM
Hogfan22's Avatar
Hogfan22
Antifreeze?
I have a 1997 Ford F-250 With a powerstroke 7.3L diesel and I am going to change the thermostat in it tomorrow and I would like to know how much and antifreeze and water to put in it.I bought 3 gallons of the green antifreeze thats whats in it.Thanks.
Old Aug 2, 2006 | 09:21 PM
jimkidd's Avatar
jimkidd
4 gallons. This is not the right way but I flush (via a tap in the heater hose) several times to be sure and get the old stuff out. Then drain it all again. Then pour in 2 gallons of antifreeze/coolant and top it off w/water. Don't forget your supplemental coolant additive.
jimbo
Old Aug 2, 2006 | 10:15 PM
Riata_Ag's Avatar
Riata_Ag
I am no expert, nor am I advising, only providing what I do to my engines, as far as coolant is concerned.
I flush all of my engines with Cascade. Drain, fill it with water from the hose while adding cup of cascade..........run it for a few miles to allow engine to reach operating temp.............drain it and allow the block to cool.............
Fill and drain 2-3 times to remove any left cascade...................
There are some better coolants on the market but for a small engine like the PSD I use Fleet Charge, its available at TSC and O'reilly's that I know of.
It already has the SCA added to it..........I use it 50/50 with Distilled water.
Can't really tell you what may or may not happen using well, spring, or city water.............Caterpillar says use distilled water...............they wrote the book on diesel engines...........so I use distilled water in all of my radiators....
PSS: I have some large engines with over 800K and some tractors with over 6500 hours and I have never(knock on wood) had to replace a radiator or head or head gasket from a hot spot. Haven't over-hauled them yet so I don't know if I have any liners pitted.
There's my $0.02 worth.................
Old Aug 2, 2006 | 10:19 PM
Riata_Ag's Avatar
Riata_Ag
I forgot to suggest picking up a couple of coolant test strips..........then you can see if your nitrite, % glycol and pH is ideal or not...........
