Sponsored by: Auxito
Sticker residue...
Old Aug 2, 2006 | 06:51 PM
ChevmaninaFord's Avatar
ChevmaninaFord
Sticker residue...
Ive had a sticker on my window for some time and I recently took it off and it left that residue. Ive heard to use alcohol and a razor blade, does this method work or is there anything else I can use without going to Advance Auto and spending 10 bucks on something?
Old Aug 2, 2006 | 07:03 PM
Patatoe1's Avatar
Patatoe1
I got bored one day and had the same problem as you. I just used a my finger and scratched it off. Took a couple minutes but was pretty easy and effective.
Old Aug 2, 2006 | 08:31 PM
Racerguy's Avatar
Racerguy
WD40 will work too.
Old Aug 2, 2006 | 09:03 PM
Beast12's Avatar
Beast12
Originally Posted by Racerguy
WD40 will work too.
I second that.
-Matt
Old Aug 2, 2006 | 10:28 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Rubbing alcohol and a rag.
Old Aug 2, 2006 | 11:26 PM
Merton Leeper's Avatar
Merton Leeper
I have used lighter fluid for years on anything I want to remove that is stickey. It kind of dissolves the glue and stickiness. And you can by a plastic container for less than a dollar. Soak the sticker, then use a towell with fluid on it and zowie, it comes off sticky free. Good luck. Mert
Old Aug 3, 2006 | 07:45 AM
projectSHO89's Avatar
projectSHO89
Originally Posted by Beast12
I second that.
-Matt
One of the few things that WD40 is actually good at.
Steve
Old Aug 3, 2006 | 03:51 PM
Smaug's Avatar
Smaug
Windex w/ ammonia works too
