Sponsored by: Kumho
alignment isssues
Old Aug 2, 2006 | 06:29 PM
Sandman1991's Avatar
Sandman1991
alignment isssues
I ve got a 94 f-150 i just put a 6" lift on it but my camber is out -2 degrees on the left side. The Toe is good and camber on the right side.The Camber adjuster is adjusted already all the way. i put in all new ball joints bushings etc. Got any ideas to what the problem could be?
Old Aug 3, 2006 | 10:04 PM
wickymustang's Avatar
wickymustang
The type of suspension on this truck doesn't like lifts or drops because of the angles. The only thing you can do is get a camber bushing that goes on the top of the knuckle where the current one is to try an bring it back in, but you will never get everything perfect with a lift on.
