Sponsored by: Real Truck
Three problems
Old Aug 2, 2006 | 05:07 PM
bblgreen's Avatar
bblgreen
Smile Three problems
I have a 1993 F250 truck 2wd. The transmission began shifting very hard ,the ABS light came on and the brakes wasn't functioning properly the speedometer had quite working. I figured it was going to cost an arm and leg to repair. I found the Ford Enthusiast site and found someone who had the same problems. I found through the site that it was the rear ABS senser. I went to Checkers and for $22.95 and about 15 minutes it was repaired. SO THANKS TO THE FORUM AND THE ONES WHO SHARED
Old Aug 2, 2006 | 05:36 PM
ryaneverk2's Avatar
ryaneverk2
That's awesome. That's what the forum's for!
Was it the rear ABS sensor, and not the VSS? (vehicle speed sensor)
Old Aug 2, 2006 | 06:43 PM
FortyFords's Avatar
FortyFords
If it was covered in a grayish material when it came out,you should consider a fluid change in the rear.
Or within a short time the new one will be doing the same thing
Rich
Old Aug 2, 2006 | 09:02 PM
bblgreen's Avatar
bblgreen
Ryan it was the rear ABS senser, it sets on top of the third member housing a litter to the drivers side. It has one bolt with a 1/2" head that holds it in. Remove that slide the old one out and the new one in. The wire disconnects right at the senser. If you have the problems I hope it works for you Billy
Old Aug 2, 2006 | 09:03 PM
bblgreen's Avatar
bblgreen
Smile
Rich, thanks for that advice it sounds like a good ideal Billy
Old Aug 2, 2006 | 09:23 PM
FortyFords's Avatar
FortyFords
The correct name for that sensor is the VSS sensor.
It feeds the abs module(abs brakes activation) and the pcm module (speedo,trans shifting).
Just so no one gets confused
Rich
Old Aug 2, 2006 | 10:09 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Glad to hear it!
Old Aug 3, 2006 | 05:25 AM
93F250's Avatar
93F250
This site has saved me a ton of time and money as well. Glad to hear it has for you!
