2bbl or 4bbl ????????????????
Old Aug 29, 2002 | 10:41 AM
mwc4275's Avatar
mwc4275
I have a 65' F-250 4x4 with a 352 in it. Currently I have a Holley 2bbl on the truck. It runs really good, but I would like to have more power. I have everything to adapt my Holley 600 on the truck. My question is, how much of an increase of power will I notice. Keep in mind that this truck is my daily driver, and I do take it off road from time to time. Will the 4 bbl increase or lower my gas mileage???? Thanks
Old Aug 29, 2002 | 05:39 PM
jowilker's Avatar
jowilker
Mitch, If you have all of the parts and the skill, put them in, I didn't notice much difference installing a 4 barrel. I have a new 390 still on the stand waiting for the rest of the truck to be finished and I stayed with the 2 barrel and stock manifolds. The 4 barrel will use more gas because you will keep your toe in it more.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Aug 29, 2002 | 06:08 PM
matt65f100's Avatar
matt65f100
I went from a holley 500 cfm 2 bbl to a 600 vaccuum 4bbl and the only noticable change was worse fuel milage. My opinion, on a driver if it works well now leave it alone. Now if I could only take my own advise.
Old Aug 29, 2002 | 07:34 PM
LxMan1's Avatar
LxMan1
Are you changing in intake manifold too? Don't use a 2bbl to 4bbl adapter, this will kill alot of power. If the 4bbl is jetted right and you keep your foot out of it, a 4bbl will get better mileage because the front 2 bbls are smaller than the ones on the 2bbl. Another benifit to going with a 4bbl is if you go to an aluminum intake you will save a ton of weight off of the front og the truck. When I pulled the stock intake off of my 460, I didn't think that I would ever stand up straight again. My Edelbrock Performer is so much easier to handle.
Jimmy
Old Aug 29, 2002 | 10:05 PM
mwc4275's Avatar
mwc4275
I am going to use a stock cast iron 4 bbl manifold. I can't justify spending the money on an aluminum intake when it don't offer any benefits, except for weight. My truck is so heavy anyways, another 50 lbs. ain't gonna make too much of a difference. Plus my 4bbl manifold was free so... Wouldn't my highway gas mileage be better with the 4 bbl? I know my town mileage will suffer. I have to take my intake manifold off anyways because it's leaking reallly bad out of the rear manifold seal. So I figure if I have it off why not put a 4 bbl on there. But my other dilema is "If it ain't broke don't fix it".
Old Aug 29, 2002 | 10:52 PM
LxMan1's Avatar
LxMan1
It would be a good time to change it since you're gonna have it apart anyway. It shouldn't hurt in town mileage either if you keep your foot out of it.
Old Aug 30, 2002 | 04:03 AM
jowilker's Avatar
jowilker
Mitch, I read most every post here, 67-72, and FE. I read more constant tuning problems with Holley, and if your truck isn't rebuilt for the use of more gas, you are wasting your time, and you are familier with the "if it aint broke thing".
John
jowilker email me
Old Aug 30, 2002 | 04:30 AM
Zen_1963_Unibody's Avatar
Zen_1963_Unibody
In reply to mwc4275
From my experience, 2bbl carbs make much more low-end torque than 4bbl carbs do. All a 4bbl carb will do for your motor is increase power in the upper end of the rev range, due to the increased cfm and fuel flow. It's purely up to you to change or not, but I recommend keeping the 2bbl if you go offroading, especially if you have the stock truck cam. You will need the low-end torque. I'm sure you're not driving like it's the Baja 1000 or anything, and I doubt you are racing on the streets.
The 2bbl will serve you much better, IMHO, for the uses that you stated. The 4bbl will trade low-end torque and possibly a few mpg for more power in the upper end of the powerband. A better cam would reap more benefits from the 4bbl than the stock truck cam will. In that case, a 4bbl would be beneficial.
If in the future you decide you do want more overall power, I recommend the Autolite 4100 over any Holley. They are a much better carb, and they are period-correct.
-Zen-
Old Aug 30, 2002 | 07:02 PM
LxMan1's Avatar
LxMan1
Once again, the smaller primary bbls will give added torque and better economy as long as you don't open the 4bbl unless needed.
Old Aug 31, 2002 | 12:50 PM
mwc4275's Avatar
mwc4275
Thanks for all of the reply's. I have to take my intake off anyways, so I think I wil throw on the 4bbl stuff just to see what happens. But I will keep my 2bbl setup handy just in case.
Old Aug 31, 2002 | 05:29 PM
LxMan1's Avatar
LxMan1
That's the spirit. I think that you will be pleased!! And Holley's are the most tunable carb around. They are simple if you know what you are doing.
Old Aug 31, 2002 | 08:35 PM
jowilker's Avatar
jowilker
That's exactly what I hear the Holley is the most tuned carb around. If you put the 4 barrel on pitch the old stuff, because you'd be a dang fool to go to all of the trouble to take the 4 barrel back off. That is a day long job.
John
jowilker email me
Old Aug 31, 2002 | 11:46 PM
oldroady's Avatar
oldroady
years and wives ago i had a f100 ranger, camper special.
352 2v. bolted in a rebuilt 352, but still needed heads. bought a pair of double sprung 390 heads from a friend, added a unknown 4v manifold,with a holley 600, and headers, with duals. the thing went like a raped ape. wish i still had it. also had adjustable rockers from an old t bird 352. bought em right of the shelf.
Old Sep 1, 2002 | 10:31 PM
mwc4275's Avatar
mwc4275
Well I got the carburator rebuilt yesterday and tomorrow I'm going to make the swap. Got everything figured out already except for the throttle linkage. I might have to change it I'm not sure. Just one of those things I have to figure out as I go.
Old Sep 2, 2002 | 12:06 AM
LxMan1's Avatar
LxMan1
Good luck to ya, were here if you need us.
Jimmy
