Sponsored by: Auxito
heater problem
Old Aug 1, 2006 | 07:05 PM
ray8495's Avatar
ray8495
heater problem
Please feel my pain. My daughter drives a 98 F-150. She told me that the heater was only blowing cold. I said it is summer and I will get to it eventually.
Two weeks later she tells me the coolant is low. I looked at the truck and coolant is leaking. So I ruined a weekend and changed the heater core. No more leak but still blows cold. I wish I checked this forum first and learned about a blend door actuator before I did the job. Before I take that dash out again, is there anyway to test it to make sure the actuator is bad? Should you hear the motor run when I move the temp ****? Thanks for your input.
Old Aug 1, 2006 | 07:32 PM
BowTieHatr's Avatar
BowTieHatr
you should here a change in air movement when it moves from cold to hot.
it could be the actuator
worse news, it could be the blend door
guy48065
Feb 28, 2015 01:28 AM
stxbrowneyes
Jul 11, 2013 10:13 PM
sscarboro
Nov 17, 2012 01:16 PM
bballard1559948
1997 - 2003 F150
Dec 14, 2011 06:00 PM
Justin's Green Truck
1997 - 2003 F150
Mar 28, 2010 09:12 PM
