04 e-350 6.0 need help
Old Aug 1, 2006 | 03:59 PM
Brian1477's Avatar
Brian1477
when you accelarate heavy like foot to the floor the engine goes flat like it wants to stall and the water in fuel light and glow plug light comes on and then it goes back to normal. any help please I would appreciate it.
Old Aug 1, 2006 | 04:06 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Have you replaced your fuel filters lately? If not, maybe you need to. If you have, drain the air/water seperater...check for presence of water. DId you get fuel at a new place? Maybe you got a bad tankfull. Any warranty left on truck? If fuel system is okay, I'd hate to say this sounds like the beginnings of turbo VGT failure.
Old Aug 1, 2006 | 04:23 PM
Brian1477's Avatar
Brian1477
fuel filters were replaced recently when problem started happening but why would the glow plug light come on
Old Aug 1, 2006 | 05:12 PM
CanadaGuy's Avatar
CanadaGuy
I'm sure that you have a wire chaffing issue. There are several areas that Econoline wire harnesses rub and short out. The usual suspects are where the wire harness runs over the top of the PCM, and around the engine oil dipstick and left engine lifting eye. Hopefully you still have warranty, cause they can be a pain to find at times.
Old Aug 1, 2006 | 07:56 PM
BowTieHatr's Avatar
BowTieHatr
i second the nomination on the harness. to many wires in a tiny space. and of course the best idea yet, engine and injectors are all on same harness. ingenious!!!!
