A/C on max not working
Old Jul 31, 2006 | 09:26 PM
CdnFord Eh's Avatar
CdnFord Eh
I have a '92 F-150, and when I move the selector to Max A/C, nothing changes. After a couple minutes, the cool air stops blowing out the vents and out the defroster ports instead. I had another switch, so I swapped it out, and still the same. Is there someplace else I should be checking?
Old Aug 1, 2006 | 08:50 PM
Ultramagdan's Avatar
Ultramagdan
Could be a vacuum problem.
Old Aug 1, 2006 | 09:10 PM
CdnFord Eh's Avatar
CdnFord Eh
I've been doing a little more searching around on it, and think I'll go after the acutator on the door, to see if it is operating properly
Old Aug 1, 2006 | 09:53 PM
Ultramagdan
That would be a good item to check.
Can you tell a difference between idle and being on the gas. That would also indicate vacuum.
Old Aug 2, 2006 | 07:30 AM
projectSHO89's Avatar
projectSHO89
Loss of vaccum from intake.
Check the supply line and any fittings for cracks/splits
Steve
Old Oct 18, 2006 | 09:21 AM
TX F-150 4x4's Avatar
TX F-150 4x4
Question Which Intake?
I have a similar problem with my '91 F-150. Which intake do you mean?
