Positive Stop Rockers????
My lifters (new) are clattering on startup for a few seconds, then they quit. It runs good, but doesnt seem to sound right at an idle (lope) and seems to be choked some while driving. It just doesnt seem to run right.....
Does anyone have any experience or ideas on these rockers? Do they work? Do I need to adjust them like normal hydraulic lifters to get the zero lash effect?
I am thinking I need to loosen them, let the lifters relax, and snug them back up til I get the lash out and then tighten them and lock them?
Any ideas here from someone who has had them or messed with them?
Thanks,<!-- / message --><!-- no sigs except when logged in -->
engineers to center the lifter's travel when the nut hits the stop. You may get noise if a stud pulls out of the head allowing lash on that rocker, while it happens it is not too frequent. I would investigate carburation as the cause of your lope and choking up.
As far as the clatter on start up I would guess you may have a delay in the oil
pressure getting to the engine (oil filter draining back). Hope this helps.
You can test by loosening all rockers until they clack, tighten back down 1/2 turn or so, and taking it for a spin. If you loosen the rockers and the lope goes away immediately, you have found a problem. You *can* use lock nuts on the rocker arm studs if you want to keep the rockers where they are, should bringing them up from the positive stop help your engine. It is not warranted... but should work.
tom
You can always pull those studs, and cut threads for new threaded rocker arm studs (with hex nut is the easiest to use) and have the bosses machined if you want to use push rod guide plates and then with hardened push rods and poly locks you will have maximum flexability in adjusting your valve lash.
Did I spend enough of your money?
As you know hydraulic lifters need to be 'pumped up' to get the proper geometry so that would explain why the problem goes away but not for the clatter. For some reason those rockers are not quite adjusted to those lifters which likely means the tolerance is off on the studs. The concept is the same between all rockers in that they should be exerting a bit of pressure on the lifter when tighened down aith the valve completely closed.
So i would check that first ie is there vertical movement in the push rod when the valve is closed. ( on adjustable rockers you usually adjust until play is gone then turn and additional 3/4 turn so that the push rod is embedded into the lifter a bit even when the valve is closed- ie no slack no clatter. I'd also measure the tolerance of those studs as far as distance from the spring seat to the stop on the stud.
hope it helps.
