66 Power Steering Gear Assembly
Old Sep 13, 2002 | 10:37 PM
JYoungJr's Avatar
JYoungJr
Post 66 Power Steering Gear Assembly
I have a 1966 F100 with a Bendix power steering gear assembly that is worn out. I want to replace it with a rebuilt unit. I have found a dealer that carries the Ford units, but I need to know the correct model/PN. It is either stamped or cast on the unit. Can anyone out there give me the numbers off their Ford power steering gear assembly? Thanks
Old Sep 13, 2002 | 10:55 PM
fomocoloco's Avatar
fomocoloco
if you change from a bendix ps unit to ford, you will have to change the steering column. it will be 3 inches too long. i will be easier to find a bendix replacement if you can. i can look up the casting numbers if you are sure that is what you want.
jim
Old Sep 14, 2002 | 06:57 AM
jowilker's Avatar
jowilker
J, The bendix was only used for a short bit, if you are a purist and must have the bendix, goodluck on the search.
The 65-79 front ends are all the same. You can get the ps setup from any mid/late 70s truck and it will bolt right up. I swapped in a 76 I-beam under my 66 and have the power disc brakes too.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member 0004 since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Sep 17, 2002 | 07:28 PM
6t6merc's Avatar
6t6merc
The required Bendix kit is still available, or at least it was a year ago when I had mine done. The Ford gear is better and cheaper, but it is a lot more work to install (the Bendix goes exactly where the manual box was), and is wrong if you have to have it original, as I did.
Eric D
Old Sep 17, 2002 | 11:31 PM
cobraguy's Avatar
cobraguy
Jag Red 54
Oct 24, 2012 02:40 PM
LARIAT 85
Aug 4, 2008 08:20 PM
250K AS
Aerostar
Jun 30, 2005 10:23 AM
Dave Green
Offroad & 4x4
Sep 20, 2004 09:04 PM
