Slippage in OD
Old Jul 31, 2006 | 10:35 AM
HUNTER10's Avatar
HUNTER10
Slippage in OD
My transmission seems to want to slip a bit going into overdrive at low speeds. Is this a common thing, or is my tranny going out (117,000 miles)? Every other gear shifts nice and firm, in fact so does OD when I'm in the higher RPMs. Just going slow it slipps going into OD (RPMs actually raise a bit when trying to shift). Any thoughts, ways to correct?
Old Jul 31, 2006 | 11:55 AM
PSNut's Avatar
PSNut
I'm thinking your T/C might be going.Failing to lockup completely would make it seem like it's slipping.Do u have a chip?
Nut
Old Jul 31, 2006 | 03:23 PM
HUNTER10's Avatar
HUNTER10
Nut, thanks again for the help. I am currently running the truck bone stock exept for the 6637 air filter mod.
Old Jul 31, 2006 | 06:41 PM
warrens250's Avatar
warrens250
You don't mention when you cnanged the tranny fluid. You could try changing it to see if the problem clears up. Don't go to synthetic right away; its too pricey for this case, where the tranny will have to be replaced if it doesn't stop slipping.
Maybe a tranny expert will chime in and tell you if maybe you have a clutch problem, which might be cheaper to fix than rebuilding the whole thing.
Warren
Old Jul 31, 2006 | 09:37 PM
HUNTER10's Avatar
HUNTER10
I havn't changed the transmission fluid since I've had the truck (only about 3500 miles). I think I'll try that tomorrow - what brand do yall recommend?
Anybody else have any thoughts? Especially the transmission experts. Thanks
