Sponsored by: Innova
HELP please?!
Old Jul 30, 2006 | 10:43 PM
sirdrumalot's Avatar
sirdrumalot
Exclamation HELP please?!
ok..in another post i said i had MTX 5500s, but I actually have 2 12" MTX 4500s seen here------ http://www.circuitcity.com/ssm/MTX-T...oductDetail.do -------
So I was wondering if someone could help me out and tell me if this MTX thunder TA4501 amp------- http://www.cardomain.com/item/MTXTA4501 ---- would be able to run my 2 subs without ruining the subs or amp?? What if I were to add a third MTX 4500....Would this amp still be able to power all three subs fine??? help would be MUCH appreciated since these will go in my first car and it is my first sound system ! thankyou ryan
Old Jul 30, 2006 | 11:30 PM
ford_mudd_runner's Avatar
ford_mudd_runner
yes it will run those subs just fine. do you have that amp already. cause if not i would suggest getting a higher watt amp and a better brand of amp too.
that amp will power all three of the subs but it will be severly underpowering them. the amp is only a 500 watt and each sub can hadle 400watts but i wouldnt put but 300watts or so to each sub. with 2 of those subs and that amp it sould be a pretty good set up each of them getting 250 watts if the amp was true on it's watts which it's not.
Old Jul 31, 2006 | 05:54 PM
sirdrumalot
i wasnt sure because each sub has 225 RMS
Old Jul 31, 2006 | 05:55 PM
sirdrumalot
is there a list of amps you could recommend for me to buy that would support three subs?
