No Power????
Old Jul 29, 2006 | 07:49 PM
1981f100's Avatar
1981f100
No Power????
hey whats up i have an 81 f100 with a 351w in it and i am not getting any jiuce to anything in my truck no lights starter wont turn over nothing will work my starter relay is getting power and i checked my ground and it is grounded good any ideals?
Old Jul 29, 2006 | 10:02 PM
Piffery1's Avatar
Piffery1
Fuse link (Green or Orange) is probably open, the one right off the battery red cable at starter solenoid terminal.
Old Jul 29, 2006 | 10:35 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
It can also be black/orange in color.
Do you have Guages or idiot lights?
Old Jul 31, 2006 | 01:00 PM
1981f100's Avatar
1981f100
i fixed it i had one of the wires on the starter relay on the wrong one and i fixed it now my starter is making a loud thump when i click it over and thats all it does
Old Jul 31, 2006 | 01:31 PM
81-F-150-Explorer
Check your battery. Make sure it has a full charge and do a load test.
That sounds like the starter is binding or the bendix is sticking.
My advice if the battery is ok, take the starter off and have it tested.
Good Luck,
Old Jul 31, 2006 | 02:41 PM
1981f100's Avatar
1981f100
i know my battery is fully charged yesterday i had it on a charger and i took the starter off and put it back on and made sure it wasnt in a bid when it kicked out but still did the same thing
Old Jul 31, 2006 | 03:35 PM
Mil1ion's Avatar
Mil1ion
Can you turn the engine over by hand ?
Old Aug 2, 2006 | 06:02 PM
1981f100's Avatar
1981f100
idk i tought maybe my shaft inside the tranny was pushed out to far so i pulled the tranny back and it was pulled out a little bit about an inch and i fixed it and it is still making the same noice but the fan and alt is is turning maybe a 1/4 inch every click
Old Aug 12, 2006 | 05:55 PM
1981f100's Avatar
1981f100
new imfo on this problem i checked to see if the motor was locked up it wasnt i could spin the flywheel by my hand i checked to see if the tranny shaft in it was to fair out but it wasnt and then i checked the starter and it was good what could it be now?
Old Aug 12, 2006 | 08:22 PM
Mil1ion's Avatar
Mil1ion
Could you spin the engine at least one complete revolution ?
Did you try by-passing the starter relay *key start* with a booster cable running directly from the + post of the battery to the starter cable attached to the starter relay ?
Old Aug 16, 2006 | 05:26 PM
1981f100's Avatar
1981f100
no i havent tried that but i relized that my tranny isnt going on straight i pulled it off 4 times and still wont go on right could somthing be wrong with my tranny?
Old Aug 16, 2006 | 10:22 PM
Mil1ion's Avatar
Mil1ion
I didn't know the trans was off.
Possible Torque Convertor Nub to Crankshaft problem.
Was this Trans on before you started the thread ?
