bump in driveline when accelerating
Old Jul 29, 2006 | 04:47 PM
fishinfool99's Avatar
fishinfool99
Just got a 2000 F250 2wd 7.3 automatic.
When I push the pedal from a dead still there is a slight bump in the driveline before takeoff.
Only happens at dead still. Slight rolling no bump.
Thanks to all.
Old Jul 29, 2006 | 05:07 PM
Crash1040's Avatar
Crash1040
Classic Ford Clunk. Mine does it.
See this thread or search the forum for more information
https://www.ford-trucks.com/forums/s...d.php?t=501447
Old Jul 31, 2006 | 09:57 PM
rockfish3's Avatar
rockfish3
Drive Train Clunk/Bump From Stop
I'll bet you have a dry splined shaft where the drive shaft splits. Take a look at "Recalls/TSBs" at the top of this web page and then select "Full Text TSBs" go to your year model and look for TBS 05-26-10 and it discusses the problem/fix. Just fixed my own truck with the same problem last week.
Old Jul 31, 2006 | 10:55 PM
empiretc's Avatar
empiretc
get a new carrier bearing and shim it, and put in new u-joints. i went through that problem.
Old Aug 1, 2006 | 03:38 AM
fishinfool99
Ok thanks guys i will check this out.
Old Aug 1, 2006 | 08:35 PM
ryaneverk2's Avatar
ryaneverk2
This webpage will be helpful:
http://www.eurekaboy.com/f250/slipjoint.htm
Need to do this on my truck as mine does this as well.
Old Aug 5, 2006 | 02:14 PM
fishinfool99
Thanks again to all.
only took about 15 min. and a cold one.
No more bump!!!
