302/ aod shift problem
Old Jul 29, 2006 | 02:31 PM
mouse777's Avatar
mouse777
71 F100, 373 RE, engine and trans from a 87 Crown Vic. Adjusted TV cable by the book. 1& 2 shift not bad but 3rd and OD seem early and I cruise along at 40 in OD @ 1300 RPM.[lugging] Any ideas folks? Thanks in advance.
Old Jul 29, 2006 | 09:45 PM
FordBoypete's Avatar
FordBoypete
Are you still running SEFI & EEC-IV ECM from the 87 CV?
Are all the pins right to Speed Sensor & TPS
is the governor functioning, & is the Vacuum Modulator hooked up right?
FBp
Old Jul 29, 2006 | 10:29 PM
mouse777's Avatar
mouse777
Yes on the SEFI & EEC-IV. The TPS is OK and within limits. There is no vac modulator that I know of. The gov is a good thought. Any way of checking it out without tearing it apart? Speed sensor I don't know anything about!!
Old Jul 30, 2006 | 12:12 PM
BobbyFord's Avatar
BobbyFord
I would adjust more throttle valve pressure. The OD is not supposed to come in until 45 mph. Use a pressure gauge on the TV port if you have access to one.
http://www.tciauto.com/instructions/431000_inst.htm
Old Jul 30, 2006 | 01:16 PM
mouse777's Avatar
mouse777
Thanks instig8r63, I did adjust the cable about 3 clicks each way and it didn't seem to make a change. I guess a pressure gage is the way to go. Any idea what the gov does ?? Thanx again,
Old Jul 30, 2006 | 05:20 PM
mouse777's Avatar
mouse777
OK!! I moved the adjuster block fwd, shortning the cable, increasing pressure, and no change. Still goes int OD at about 37 mph. Cruise at 45 mph in OD at 1300 RPM, and lugging. I don't know much about the governor but I'm looking for what to hit next.
Old Jul 31, 2006 | 07:14 PM
BobbyFord's Avatar
BobbyFord
I would try a Trans-Go shift kit. In 87 they were still working the bugs out of the AOD transmissions. Try a TSB search on that particular year trans. Look for something related to soft shift complaints.
Walwal44
Dec 30, 2014 03:11 PM
Whitey Ford
Oct 5, 2013 04:20 PM
tommyl
Dec 31, 2004 06:21 AM
Dragrazor
Feb 12, 2004 02:23 AM
