4WD switching problems '99-'01
Old Jul 29, 2006 | 01:46 PM
RangerShppr's Avatar
RangerShppr
I have looked at four manual 5spd used '99 - '01 Rangers. Three of them had problems when switching into or out of 4WD. Usually the problem was only in Low range, but sometimes the High would not engage either. I realize the vehicle must be stopped, in neutral, and with the brake pedal depressed in order to engage or disengage 4WD Low. The fourth Ranger I am looking at has already had the electronic motor replaced that engages/disengages the 4WD. Anyone had similar problems and I am wondering if I will have problems later with the one that already had the replacement?
Old Jul 29, 2006 | 10:44 PM
wendell borror's Avatar
wendell borror
Alot of the problem people have is from not being used, they seldom use high range, and hardly ever use low range. Use the 4 wheel drive system once a month in both ranges. Drive it around in your yard, or back in forth in a parking lot, don't make hard turns on dry pavement while in 4 wheel. I live in the country, and have 3 acers, so it's easy for me, city folks may not have a place to play. The electric shift motor tends to freeze up from nonuse. I'm sure some others will have some idea's as well.
Old Jul 30, 2006 | 11:36 AM
PW01's Avatar
PW01
I have an 01 4x4 and have never had any trouble with engaging the 4 wheel drive.
Old Jul 31, 2006 | 02:05 PM
RangerShppr
comments found using 'search' under 'Forum'
After doing a search on 4WD switching in the Forum drop down menu I was able to read about enough people who had trouble with the PVH system. I think I'll shop for a '97 that can i can find manual hubs for. I went to Tellico4x4.com and I didn't see manual hubs for '98-present. thanks!
Old Jul 31, 2006 | 04:00 PM
blueranger99's Avatar
blueranger99
RangerShppr,
Try looking here:
http://www.tellico4x4.com/product_in...ducts_id/26509
Old Jul 31, 2006 | 04:41 PM
wendell borror
AVM makes manual hubs for the 98-2000, I have an 04, it's a direct engagement system, no axle disconect, or pulse vacume of any kind.
Old Jul 31, 2006 | 06:59 PM
Alan D.'s Avatar
Alan D.
I got warn hubs for mines. lets compaire
Stock auto Hubs- Didn't enguage = crap.
Warn Manual Hubs- Work great, no problems = happy me.
