gauge cluster
Old Jul 29, 2006 | 01:24 PM
hydrosmith's Avatar
hydrosmith
gauge cluster
Hey guys I got my hands on a round instument panel from a '76 f600 for my '69 C/S and it came with the gauges. I had to swap in the wiring harness from the '69 panel since the '76 had a printed circuit feeding power to the gauges and I had to run a ground wire to the back lighting bulbs and I used the instrument voltage regulator from the '69. But the problem is the temp gauge is maxed out when it warms up. Is the sending unit not compatable from '69 to '76?
Also the '76 panel came with a transducer attached to the speedo. What is this thing good for?
