Quick Pyro Q?
Old Jul 28, 2006 | 10:25 PM
turboale's Avatar
turboale
Quick Pyro Q?
So I'm 80% done installing my gauges and I have everything wired up...
I go to test the gauges with a battery charger set to trickle charge and so far everything is working great except for the pyro. It came in the box at about 375 degrees and when I hook everything up it stays there and doesn't move. The sensor appears to be hooked up correctly (red-red, yellow-yellow), the other two gauges are working properly so I have good grounds/12v and I even rewired everything to double check that it wasn't the connections. Am I missing something or could it be a bad gauge? Does the pyro sensor need to be grounded? I wouldn't think so since there are two wires going to it instead of the one going to the trans sensor. Does it have to be heat cycled or something before it gets a correct reading? Any help would be greatly appreciated!
Thanks a million!
--Austin
Old Jul 28, 2006 | 10:30 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Are they Autometers by chance?
Old Jul 28, 2006 | 10:33 PM
mech2161's Avatar
mech2161
I believe AutoMeter had a bad run on probes. Contact the place you bought it from and they can get you a new one.
Old Jul 28, 2006 | 10:35 PM
mech2161's Avatar
mech2161
I just installed the heads up display from TS today. Love the memory recall. Look here and scroll down. http://www.discountpowerparts.com/
Old Jul 28, 2006 | 10:40 PM
Tenn01PSD350
I was looking at that. Cool. Too bad they came out with it after I bought my gauges. #$!% They don't do your tunes do they?
Old Jul 29, 2006 | 01:43 AM
jtharvey's Avatar
jtharvey
That's a pretty sweet display Kevin.
turboale, like Kevin said, if it's an Autometer check with them about the bad run of pyros.
Old Jul 29, 2006 | 01:55 AM
turboale's Avatar
turboale
Its a Dakota Digital sending unit and a Stewart Warner gauge... Got everything from Summit Racing.
