Is this stupid?
Old Jul 28, 2006 | 06:10 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Is this stupid?
Myy son just picked up a new hi-po short block 302 for his Mustang GT. This is a block that "the best shop in town" just fully machined, polished the rods, you name it. A grand worth of work. So to load it on my truck, they screwed an eye bolt into the crank snout, and lifted it up and into the truck!
Maybe it's just me, but that seems like a really lazy-a$$ way to handle a fine piece of machinery! This is a shop that probably turns out 3 or 4 engines a day, and this is the best they can come up with??? If the crank snout wobbles when it's all installed, you can bet I'll be down there in a heartbeat!
Tell me if I'm being overly sensitive here....
Old Jul 28, 2006 | 06:17 PM
Col Flashman's Avatar
Col Flashman
No. no you are not!
It was Lazy on their part & Stupid.
Old Jul 28, 2006 | 06:32 PM
4tl8ford's Avatar
4tl8ford
Engines arn't designed to take much load in that direction. (Fore/Aft)
Old Jul 28, 2006 | 07:37 PM
AXracer's Avatar
AXracer
Not with MY engine they wouldn't!
That's why the factory bolts lift tabs to the block. There is a thrust surface on a main bearing that has precision clearances to keep the crank from "walking" in the block. It's not designed to carry the weight of the engine.
3Mike6's Avatar
3Mike6
Hmmn, best shop in town and a grand for the work?
I have to move to a different location
Old Jul 28, 2006 | 07:40 PM
AXracer's Avatar
AXracer
Doesn't show much respect for their own work now does it?
Old Jul 28, 2006 | 08:37 PM
Nuthin's Avatar
Nuthin
I'd have gone Postal on the spot, I'm afraid.
Sheesh!
Old Jul 28, 2006 | 08:58 PM
Randy Jack's Avatar
Randy Jack
Ditto. Color me freaked out!!!
The engine rebuilder in my town gave my engine back rolled out on s unbiversal engine cart the supported it by the motor mount lugs and with a sheet metal bracket custom-made to fit the carb bolts on my intake manifold. C of G, exactly. Pick it up...set it down. Sweet! They handled it like a baby. They made sure it was tied down well before they waved goodbye. I think they cared about how it got home.
And I paid $1025.
Old Jul 28, 2006 | 09:21 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Fortunately or unfortunately, I wasn't there, my son told me about it. He thought it was a clever way to pick it. I haven't told him what I think about it because he thinks I'm "too fussy".
Randy, if your engine had an intake on it (was assembled), then you got a better deal, this was just a shortblock. Bored/honed, new Motorsport cam, cam bearings, new pistons, line bored and crank polished, balanced, Clevite bearings, decked, and a new timing gear set (Ford Motorsport). My son tells me it was "a grand", hmmmm....
He's got existing Trick Flow heads, intake manifolds, headers, bigger mass air flow, etc. to complete it. Chip off the old block, eh?!
Old Jul 28, 2006 | 09:27 PM
Nuthin's Avatar
Nuthin
Uh, not if he thought it was 'clever' and you're too 'fussy', sure doesn't sound like it.
Old Jul 28, 2006 | 09:51 PM
R Pope's Avatar
R Pope
While that's a novel way to lift an engine, a 302 shortblock isn't heavy enough to damage anything.
Old Jul 28, 2006 | 09:57 PM
Randy Jack's Avatar
Randy Jack
Yeah, Ross. My engine rebuild was a long block, balanced, etc. They let me have the heads after magnaflux so I could match-port them. Then they finished the top end and gave it back blueprinted. It's a 351C. They do a couple hundred engines a month. They are 8 miles from my house.
I am pretty pleased with the deal.
Old Jul 29, 2006 | 12:09 AM
imlowr2's Avatar
imlowr2
I wouldn't recommend this way of lifting an engine either. Apparently, this machine shop uses this method frequently. That's a scary thought!
Old Jul 29, 2006 | 06:33 AM
4tl8ford's Avatar
4tl8ford
What a novel way to insure "Job Security"
Old Jul 29, 2006 | 06:58 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Perhaps the folks doing the loading and unloading are not the precision mechanics??? I know that's not an excuse but maybe they have some former Micky Dees hamburger flippers doing the grunt work and need to know about this!
Vern
