Inline 6 header
Old Aug 8, 2006 | 02:43 PM
optikal illushun's Avatar
optikal illushun
hedmen doesnt make a single outlet headers AFAIK...not new at least.
80-95 2wd and 4wd will work.
i spent $160 for the headers
$150 to get them ceramic coated
$135 for the exhaust but i had the muffler and cat so about $250...
Old Aug 9, 2006 | 07:02 PM
85-89ford's Avatar
85-89ford
I am ordering a hedman header (hed-89300) and flowtech red hot mufflers (big-50252). Has anybody used the mufflers? if so whats your opinion.
Old Aug 12, 2006 | 12:43 AM
benton's Avatar
benton
I'm in the same boat. Exhaust is mangled (leaking think at the manifold, one cat missing, 2" pipe welded into the 2 1/4", crap muffler and short pipe that doesn't even make it to the rear axel) basically need whole new deal. cost is more important than performance/sound. Any ideas (88 150 4x4)
Old Aug 13, 2006 | 12:58 AM
OrdoDraconis's Avatar
OrdoDraconis
the headers from clifford are abour 339 without shipping i got a set of hookers for my project truck from ebay for 115 with 25 dollar shipping
Old Oct 4, 2006 | 02:35 PM
oldharper's Avatar
oldharper
Will the same hedman 89300 work on the '96 300i6?
Old Oct 4, 2006 | 06:39 PM
79greenmachine's Avatar
79greenmachine
http://store.summitracing.com/partde...5&autoview=sku The link above has hedman headers for $149.00 not sure of the quality but they are made for the 300 I6's
Old Oct 10, 2006 | 08:32 PM
nastruk95's Avatar
nastruk95
"hedmens will fit, im running them. just be weary if u have AIR injection at the head"
How did you get them to fit well? I ordered them and was going to put them on with the camshaft, but the flange was a different thickness then the intake manifold so the bolts wouldn't hold down both the header and intake evenly. Is yous supported only by the three lower exhaust only bolts?
Old Oct 11, 2006 | 12:07 AM
optikal illushun
what they are concerned about is crossmemebr clearence and interference of the driveshaft (not applicable) and starter, etc...
quite honestly, i did reuse all the stock hardware but has one bolt left over (confirmed it wasnt used). everything went back together like clock work and all the stock hardware worked.
make sure u run a bolt in the rear most hole because the header will use that as a support in the notched end on the back of the header. i did run into this problem but figured out that notched hole was the key.
if u need help ill get a pic in my gallery.
Old Oct 11, 2006 | 12:18 AM
coldnorthpole's Avatar
coldnorthpole
Does Hedman make headers for the 93 F150 XL 4x4 inline 4.9L Inline 6?
Old Oct 11, 2006 | 07:18 AM
optikal illushun
did u even read this thread?!
Old Oct 11, 2006 | 09:47 AM
Silver Streak's Avatar
Silver Streak
That's what I was wondering.
A quick search probably would have alleviated the need for the whole thread. This topic has been covered several times in recent months.
Old Oct 12, 2006 | 02:33 PM
bchunter's Avatar
bchunter
What do you guys think the difference would be between the header and the split EFI manifold? I would think that the header would give a bit better performance due to the fact it equals out the exhaust length, but when you look at the efi manifolds, they are not very big to start with. Any thoughts?
Old Oct 12, 2006 | 03:12 PM
  #28
rusty76's Avatar
rusty76
I don't know about that but Pacesetter makes a single outlet header for the I6 best price I've seen $250.00 hope this helps a bit
Old Oct 12, 2006 | 03:16 PM
  #29
optikal illushun
link it because last time i seen the pacesetter header it was dual outlet.
Old Oct 12, 2006 | 08:11 PM
  #30
coldnorthpole
I asked because my mechanic called Hedman and they said they don't make headers for the 93 F150 XL 4x4 inline 6 4.9L?
Hedman told him that they only made headers for the 2x4 pickup.
Is this wrong??
