Sponsored by: Kumho
suspension mods
Old Jul 27, 2006 | 09:33 PM
Ford347's Avatar
Ford347
Question suspension mods
I have a 79' F-100 2wd I was wonder what my options were for front suspension. Im wanting to lower the truck not slam it. Has anyone ever done a rear axle flip on a truck like this and if so how much did it drop and did you have to notch the frame or was there enough clearnce. What did you or do you do for the front?
Old Jul 28, 2006 | 02:05 PM
MBBFord's Avatar
MBBFord
I'm sure someone sells drop coil springs, but you might get into a bind with the I-beam suspension. It doesn't like lifts or drops, b/c it is designed to be like it is. Now if you heat up the I beam to bright red and bend it just right, then you'd be ok.
If you don't do this, your tires will ride like this /---\ (causeing uneven tire wear, and makeing your alinement off alittle).
This all depends how much you drop it now, you might be able to get by with 2"s or so.
For the rear you could swap the leafs to the bottom, and lower it a good 2-4"s and I don't think you have to notch the frame any.
Or you could just take a leaf out of the pack.
Old Jul 28, 2006 | 02:12 PM
MBBFord's Avatar
MBBFord
https://www.ford-trucks.com/forums/s...d.php?t=510539
There are a few people in that link that have done what you want to do, and could help you out alittle more.
Old Dec 30, 2006 | 11:26 AM
daveheld's Avatar
daveheld
have you considered an IRS to lower your rear suspension?
If you were in Florida I would deliver it in person, but Canada is a little too far for me to include delivery.
Check out http://team321.com/truckirs/truckirs.html
for more details.
email me with any suspension questions you may have.
dave
Cocoa Beach FL
