460 conversion exhaust man
Old Jul 26, 2006 | 11:57 PM
quentinorciuch's Avatar
quentinorciuch
Hi i have a 460 in a 78 f 150 4x4, currently the engine is not properly mounted, i am going to buy L and L engine conversion brackets. my problem is right now i have exhaust manifolds on the passenger side from a lincoln(d4ve), i went to the junkyard today and picked up another passenger side exhaust maniold because the lincoln one that i have on the truck is cracked. The one i got at the junkyard has d4te casting numbers on it and is not the same angle to connect to the exhuast pipe. I am wondering what exhaust manifold will fit correctly on my truck once i buy the L and L brackets and bolt the engine up properly?
thank you
ps any help would be great i need to talk to the junkyard guy tomorrow and hopfully get one that fits if the dt4e exhaust is the wrong one
Old Jul 27, 2006 | 12:49 AM
Mil1ion's Avatar
Mil1ion
That's correct.
We are always mentioning to people to get the manifold off a 460 truck for their swap.
Take the truck manifold and modify the exhaust to fit properly.
Old Jul 27, 2006 | 12:55 AM
quentinorciuch
thank you...so i should go buy the driver side exhaust maniold from the truck?
Old Jul 27, 2006 | 01:11 AM
FordBoypete's Avatar
FordBoypete
The Driver side OEM Exhaust Manifold is the same for a car or truck.
The right or Passenger side is the one that must be off a Truck because a Passenger car manifold hits into the frame rail making exhaust connection impossible. Just get a right side truck manifold.
And if salvage Yard has a 460 truck get all 6 of those engine mount parts and use them. I would tell you the OEM truck Mounts are superior to any aftermarket set up. The insulators are available & can be replaced if the ones at the salvage yard are weak or bad. . . .
FBp
Old Jul 27, 2006 | 06:19 AM
banjopicker66's Avatar
banjopicker66
FBP: Does the 4x4 use the same mounting setup for the 460 as a 2x4???
Old Jul 27, 2006 | 09:47 AM
Mil1ion's Avatar
Mil1ion
Since they never put 460's in 4x4's I would think NO.
Most 4x4 people opt for the L & L mounts to get the extra height away from the cross-member.
They also get the rear sump oil pan & Pickup tube.
Old Jul 27, 2006 | 10:01 AM
FordBoypete
BP66
He's right there are Pan clearance issues with the front Differential, it needs hieght and like Dennis said the rear sump set up too. There are no OEM stands & brkts for that retro fit. . . .
You building a Mudder to keep up with the recent weather there, BP?
FBp
Old Jul 27, 2006 | 10:38 AM
banjopicker66
No, but thanks FBP! I was asking because it looked like you suggested he get the OEM 2x4 mounts - but he has a 4x4.
I have the OEM 2x4 mounts.
I also have an '80 or later pan, dipstick and oil pump, nad boy is it ever easy to change oil now!
Old Jul 27, 2006 | 11:45 AM
SoArkSI's Avatar
SoArkSI
just trying to add to the information....i have a 3/4 ton 2wd with a 460 and i am putting the 460 in my 1/2 ton 4wd. my question is that will the 460 motor mounts in the 3/4 ton work in my 1/2 ton the same way??? also there might be a chance that my frame was originally 2wd and was converted. my situtation is very complicated so any help would be great. i figured all this info in one thread would be better than me just starting another one.
Old Jul 28, 2006 | 12:15 AM
quentinorciuch
thank you for all the help...im gonna keep the passenger side truck exhaust and just use my lincoln exhaust that is already on my drivers side
Old Jul 28, 2006 | 08:52 PM
Mil1ion's Avatar
Mil1ion
SoArks.
What year truck is this ?
If a 77 what are the last 6 digits of the vin#?
I suspect the 460 MM's will fit the 250 the same as the F150.
But because it may be a 4x4, then the L & L mounts would be needed.
They put 460's in F250's & F350's 4x2's.
Old Jul 28, 2006 | 11:10 PM
FordBoypete
Red face
Oh WOW. . . .
I Did BP. . . . DUuuuH
I thought I tasted shoe when I typed that!
THANX
FBp
