Don't know if this should be here or not, but here goes.
My shop has a 1993 Ford Super Duty car Hauler. Has a 460 EFI, and and automatic overdrive trans. It has the biggest trans cooler that we could find to put on it, and were running Amco Mercon V Synthetic fluid.
Problem I have is the trans has lost 2nd gear, and jumps in and out of OverDrive now. Was wondering if anyone can give me some info for a reputable place to get a rebuilt, remanufacured, or new trans.
This will be the 2nd time for putting a trans in this, not the funnest thing in the world, so would like this to be the last time, if possible.
give us a call monday. we can talk about your problem and help get you into a beefed up unit.
loosing second gear you most likly lost the clutch pack. and our web site may help you understand better what happened try www.level10power.net and www.levelten.com
