Do the easy stuff first check your belt,it may be loose or glazed and is slipping when you use the steering system, also make sure there is enough P.S. fluid in the system Eric
>Eric
ERIC
I wish this could be a possibility. My tired arms prove that this guy DOES NOT have PS. This is a manual beast. You do not, rpt DO NOT steer unless the truck is moving...
