New Dome?
Old Jul 26, 2006 | 06:10 PM
Terran's Avatar
Terran
New Dome?
I want to upgrade my broken dome lamp with somthing nicer that i can put an LED bulb in, i was looking at these http://broncograveyard.com/images/catalog/PICT1939.JPG. Will that fit my truck? Anybody else done this?
Old Jul 26, 2006 | 09:25 PM
biz4two's Avatar
biz4two
Arrow
I have seen it done...on many '73-'79 FORD trucks, but the bad part is I do not know what the procedure is. Sorry...I could not be more help.
biz
_______________________________
1976 F150 LWB 390FE NP435 NP205 4x4 3.50s
Old Jul 26, 2006 | 09:39 PM
77f2504by4's Avatar
77f2504by4
if memory serves me correctly, those will fit, but unless its from a truck, the map lights wont be at the right angle. but im not 100% on that.
Old Jul 27, 2006 | 01:01 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Yes that's correct.
The map lights will have to be wired up as well.
Trucks without map lights or cargo lights don't have the wires in the cab harness going up toward the dome lamp. They just have a single dome lamp wire going up to the lamp. The truck is wired for these lamps however further down the harness toward the main harness.
You will need to get the proper harness extention for the map and dome lamps that goes up the back of the cab for the map lights to function.
I do believe early 1980's Dome and Map and cargo light harness extentions are compatible, with possibly a little bit of modification needed on this paticular year truck.
Old Jul 27, 2006 | 05:33 AM
Terran's Avatar
Terran
Well is there a better option? I don't really want the $80 one, could i just get one out of a junk truck and put it in? one without the map lights?
Old Jul 27, 2006 | 09:44 AM
Mil1ion's Avatar
Mil1ion
I tried putting one of those in y truck and right off the bat found that the wiring would be a hassle, so I stayed with the original.
Terran, are you now asking about a OEM same replacement dome light lens or assembly or something else ?
Old Jul 27, 2006 | 11:17 AM
Terran's Avatar
Terran
I want somthing that i can replace the crappy OEM light with, i'd like to go LED so i can never worry about it again!
Old Jul 27, 2006 | 12:39 PM
81-F-150-Explorer
I'm not 100% sure on this, but...
Try getting a dome lamp assymbly out of a early 1980 F-series. One without the map lights. They take a 912 light bulb, and have a socket that you could fit a LED into if they make one to replace the 912 etc....
They look very different from the original on the truck however, and I am not 100% sure it's compatible. It would be, go and get one and try it etc...
What is wrong with the lamp you have now? Does the light keep burning out or something? Do you need a new lens for the lamp? Is the lamp dim? All those problems can be fixed, without swapping asymblies.
